Re: Here we go again...36"
Have a look at the FornoBravo oven plans. It gives the detail there.
If you use bond beam blocks or knock outs filled with reo you can skip the angle iron.this is the standard method of building lintels and looks much neater and probably much stronger.
Looking good, Rocciarm. You'll be glad you leveled those block up when you get back to it. It'll make things a lot easier going forward. Nice job.
It might have to do with the size of your pic files. I reduce mine through an image resizer and they end up 1600 x 1200 and they are usually under 100kb. They load much more quickly and the quality is fine for the purposes of the forum.
Once you have the access you need to 'go advanced' click on the paper clip and depending on the size of your pics you can get up to 5 in the one post.
All the best with your build. Looking forward to following your build.
Hi Rocciarm and welcome. Best of luck w/build #2!
Keep those photos coming!!
Tags: None
