Starting over
  • thesharkbar
    • May 2015
    • 34
    #31
    Re: Starting over
    I already have the floor bricks the are 40mm and the bricks on the dome are normal size bricks I'm just wondering if 40mm is ok or should I have the same size as the dome as I've already pulled it down twice I just want to make sure before I go ahead
    Just paranoid lol
      • 2848
      #32
      Re: Starting over
      G'day
      I'd go with what you have, you've got the insulation covered now so that's the important bit.
      • deejayoh
        • Jul 2010
        • 1893
        #33
        Re: Starting over
        What are those floor bricks made of? Are they firebrick, or something else? They look a bit different, why I ask.
        Your oven looks to be on the smaller side. maybe 32 inches? If it were me, I would use standard firebrick. If you fit them inside the oven, it's maybe 20 bricks. But I know that firebrick is pricey down under - so that's probably a consideration. Why it's pricey I really don't know - given that you have about half the world's alumina reserves. But that must another thing I don't understand.
        • thesharkbar
          • May 2015
          • 34
          #34
          Re: Starting over
          The floor ones I have are fire bricks I picked up about 30 of them at $1 a brick and the normal fire bricks at $2.50 each
          The normal ones will probably get me by for the dome, I did buy about 20-30 extra but as I've pulled it down twice now I'm slowly running out of bricks lol
            • 2848
            #35
            Re: Starting over
            G'day
            Use any chipped brick in the front quarter of the oven. Once it's complete they can't be seen unless you climb headfirst in oven on your back and look back to the entrance.
            • thesharkbar
              • May 2015
              • 34
              #36
              Re: Starting over
              Hi all, back all relaxed and ready to start again
              Had a wonderful time on the cruise
              Ive rebuilt the base and have done the slab on the top, now ready for the insulation and start again third time lucky lol
              Couple of questions i have
              1 with the insulation board they told me not to get it wet, so does that mean that i dont use mortar on the floor bricks
              2 since i bought seconds for the floor bricks and they are not all even height wise can i put a small bed of sand in between the insulation board and the floor bricks to level them
              Thanks all in advance
              Adrian
                • 2848
                #37
                Re: Starting over
                G'day
                The hearth bricks are not mortared at all. Lay them on 50/50 sand and powdered clay. Make sure the sids of your brick touch before dropping them in position. A tap with a rubber mallet and a straight lenght of wood will see them level
                First layer of dome bricks are mortared on the sides but not the bottom. If you are laying them on the insulation and you concerned with water from the mortar a smear of table margerine will protect it. It will bio degrade and will not effect anything.
                • thesharkbar
                  • May 2015
                  • 34
                  #38
                  Re: Starting over
                  Thanks Dave
                  First layer of dome bricks will be on the floor bricks
                  How thick should the layer of sand and clay mix be?
                  • Greenman
                    • Feb 2013
                    • 1123
                    #39
                    Re: Starting over
                    I would cut the floor bricks to fit inside the dome and lay the first course of dome bricks on the insulation and mortar them together but not down.
                    I am sure that there are two schools of thought about this but having the floor and the dome independent of each other makes sense to me. It has also worked for me and that is where my opinion is formed.
                    Cheers ......... Steve
                    • thesharkbar
                      • May 2015
                      • 34
                      #40
                      Re: Starting over
                      What's the pros and cons with having the floor on the inside of the dome compared to under the dome?
                        Re: Starting over
                        Dome on top of floor means you don't have to worry about making really accurate cuts for the outer floor bricks. Forget about replacing any of those bricks down the track, they will be extremely difficult to remove and replace.
                        Floor inside the dome will take more time to cut and lay.
                        • Greenman
                          • Feb 2013
                          • 1123
                          #42
                          Re: Starting over
                          My understanding of this is that if there is a small gap between the hearth and the dome that each can expand and contract independently. The gap will fill with ash and poses no issues that I have heard mentioned on the forum.
                          The ovens I have built have been done this way and there are no issues with them.
                          As for the cons............. over to the people who have a different experience to mine. I suspect that both would work fine.
                          • thesharkbar
                            • May 2015
                            • 34
                            #43
                            Re: Starting over
                            Hi all
                            got around to doing some more work on the wfo
                            decided to go with the dome on top of the floor
                            finally feel like I'm going forward again
                            First one going backward pulling it apart to put insulation in
                            second one all the bricks from the floor and the dome cleaned and numbered
                            third one the new insulation and the last one, where I'm at now ready to start the dome again
                            • thesharkbar
                              • May 2015
                              • 34
                              #44
                              Re: Starting over
                              Slow going at the moment as Ive been put on day shift for 4 weeks and i can only work on the oven on saturdays as sundays are taken up with the kids sports
                              Got the arch up and most of the first course in yesterday
                              • thesharkbar
                                • May 2015
                                • 34
                                #45
                                Hi all
                                Been a while the four week has turned into fourteen weeks and looks like i could be there for another eight to ten weeks
                                Im going to attempt to get some done this week end as the sports have all finished
                                Keep you all posted
