Originally posted by gastagg
View Post
30" Pompeii in Minneapolis
- 2 likes
Originally posted by gastagg View PostWow, thanks for the information Dave. How much SS fibers? How much polypropylene fibers?
Only around half a handful of the polypropylene fibres for your casting, but you need to mix the brew about double the time that you would normally because they take more time to dispers properly.Kindled with zeal and fired with passion.
Thanks Randy...took a lot of rubber mallet beating to get the cement down into the form . I tend to error on the side of less water. Most of the seams have some stuff squeezing out a bit, so I'm very hopeful that it will come out OK. Got a heater under the wrap for the next few days to keep it in the 40s in there
Pulled the forms today. Am pleased with the results. Soon as I get some warm weather for a few days, going to put on a layer of blanket, install metal mesh, and then stucco. Thanks for the help Dave. I'll be honest with you all...if I were doing this again, I'd build a cast oven.
Thanks Randy! I put a lip on the front edge to minimize smoke escaping from the front too. I plan to make it all the same color. Going to stucco out the entry arch and then put a final layer on the whole oven. Then I'm going to use a Behr stucco product to seal and give it a consistent color. I have a fund raising party for the performing arts program at my daughters high school on May 21 so I hope to have all things done by then. Stucco paint requires 1 month before applying on fresh stucco.
Wow sounds like a great plan. I can't wait to see it when you are done. The fund raising event sounds like a fun time. How many people are you expecting to have for it. The most pizzas I have done so far is 16. But if I kept it simple and had a helper I could maby see doubling that with out to much effort. Good luck. It is looking great.
Randy
The party will be 34 people including the hosts. I've done about 2 dozen a couple times. I'm planning to have the crusts pre-made as that seems to be the holdup in a party. Also need to have the oven real hot at the beginning and keep a fire going throughout as many pizzas over time cools things down a bit.
Cast arch turned out nice.Russell
