Hey all, just wanted to give you an update.My 42x16 1/3 brick oven has been born on 5/12/07 at 1:00 am! I was worried about the aggresive arch on this but, for no reason at all I guess. This heat stop 50 is sweet. Had her up to about 500 so far! Question for you all , is zonolite (coated vermiculite), ok for loose insulation, or is the the silicone coating bad at these high temps? I am planning a stucco enclosure then filling with loose insulation. Check out these pics. Seeing the first fire in this thing was amazing!!!!!!!!!!!, wife and i were up till 3:30, and back up at 8:00amto burn it again!
