I've just finished cutting my concrete blocks to fit over the angle iron with a circular saw fitted with a masonry blade.
It worked well but I don't think it will work with the fire bricks because of the more delicate cuts required.
Has anyone used a circular saw with masonry blade to cut firebricks or am I better off getting a grinder or (very expensive) brick saw?
Or will a power tile cutter do the trick?
I know I could hire something but with limited time each day to work on the oven that would end up costing more than a new brick saw! And I could use a bolster and hammer but I know my brickwork limitations.
cheers
ian
cheers
ian
