james requested that i post some specs on the preformed archway bricks i am using for my doorway header, and for the top of my dome.
these numbers are an industry standard, so one should be able to find these from different manufacturers. unfortunately, the supplier i got mine from (HWR---you can find their distribution centers all over the U.S.. check on hwr.com) only had archway bricks in a superduty grade (the "clipper" grade, 52.6% silica, 42.2% alumina), so they were more expensive. however, the price of the arch bricks in the clipper was not that much more expensive than the straight 2.5"x4.5"x9" bricks. nonetheless, here's what i used, and what i paid:
#1 "clipper" ARCH BRICK in a 2.5" series---tapering from 2 1/2" to 2 1/8"---$2.95
#2 "clipper" ARCH BRICK in a 2.5" series---tapering from 2 1/2" to 1 3/4"---$2.95
#4 "clipper" ARCH BRICK in a 3" series---tapering from 3" to 1"---$3.27
my entire 18" tunnel from the oven doorway to the actual exposed entrance cost me $80.
the 2.5"x4.5"x9" straight clipper sells for around $2.75, so the arch bricks are not really that much more, relatively speaking.
so...if someone could just find a supplier with low or intermediate duty archway bricks, the price should be comparable to a straight brick, and the entire dome could be made much stronger. good luck.
