Hello all
This is my first post on Here. I started my Pompei Oven Last week. And so far have built the base, and poured the structural slab, and the insulating slab. My question is this: How thick should the insulating slab be? Also, my slab is 69" x 84", I used 3 full bags of Perlite along with 2 large bags (66 or 88lbs) of Portland cement, and topped up with sand to achieve 3/4 yard on finished mix. This was done by a company here in the Niagara Region called "U-Cart Concrete", who delivered the mix to our Café to be poured on-site. Did I use enough Perlite? The insulating slab is 3" thick, will this be thick enough? If not, should I first lay down a first layer of firebrick, then lay my floor down on top of that? Any help would be greatly appreciated.
Rick
I will post pics on next thread (soon as I shrink them down to under 100kb)
This is my first post on Here. I started my Pompei Oven Last week. And so far have built the base, and poured the structural slab, and the insulating slab. My question is this: How thick should the insulating slab be? Also, my slab is 69" x 84", I used 3 full bags of Perlite along with 2 large bags (66 or 88lbs) of Portland cement, and topped up with sand to achieve 3/4 yard on finished mix. This was done by a company here in the Niagara Region called "U-Cart Concrete", who delivered the mix to our Café to be poured on-site. Did I use enough Perlite? The insulating slab is 3" thick, will this be thick enough? If not, should I first lay down a first layer of firebrick, then lay my floor down on top of that? Any help would be greatly appreciated.Rick
