So I guess I am not much of a planner and built the structure over my oven before building the oven and now I am faced with a predicament. My oven floor is 74" from the roof of the structure and I remember reading somewhere that if a chimney is too long it can suffocate the fire in the oven. I think with code it needs to be 15" above the roof of the structure so with a 12" tall door my chimney would have to be at least 77" tall. Forgive my ignorance but if I did a really short chimney would the heat dissapate quickly enough (see pic below for how open the structure is) or could I put some sort of barrier up there to block the heat?
And my second question is about the oven opening. I got a response from someone the other day that regretted making there opening small to keep the heat in better but had a hard time reaching the sides of the oven with a peel. Can I flare the bricks for the opening (see pic 2) with the idea that it would provide greater access and also provide a seal, on the sides at least, when the door is put in place? I realize I would have to make my vent flare as well but I plan on casting one from concrete anyways.
Thanks so much.
If anyone is in the Prtland area and wants a very active sourdough starter let me know. I am more than happy to pass it along.
Thanks so much.
