Bricks are here now! Dry fit in garage before the big day tomorrow. Will set the 9 bricks shown in front with high heat mortor and also mortor in spaces between these upfront ones incase the winter rain and freeze cause any problems. These upfront bricks will be covered with the arches and vent for chimney. Bricks within the circle just get set with fireclay and sand so they can be replaced if they chip or crack. Outer bricks on circle area will be mortored in place also. I have a couple of questions?
How long do I need to soak bricks before setting in fireclay mix and the high heat mortor mix? Also not sure about after things have been layed in place do I need to put a wet sheet or something over it all. Should I just spray with water each day....Thanks in advance Wayne Bergman Garden Bay BC
