I just finished my dome and need to make a decision as to the chimney. With the rains coming and the material I used to cover the roof of the pergola I really don't want to go up and through the roof. I have added a few pics of the oven and structure as well as a pic from Balty that shows what I am thinking would work. I have about 50" or 110cm between what would be the top of the small chimney and the rafters of the structure. I live in Portland OR where it is usually at least breezy if not downright windy and the ceiling of the structure is open on all sides as to not trap hot air. I also would rather insulate and put up metal sheeting above the oven than go through the roof. Not having used a brick oven before I just wonder if there is too much heat coming out of the chimney to be a true hazard or if it would dissapate quick enough. please chime in with a yes( I need a chimney through the roof) or no( I can be lazy and not burn down my structure.) I will put an overly sufficient spark arrester on and may revisit the longer chimney after the rains stop next year.)
Thanks so much,
darren
Thanks so much,
darren
