Kemo's South Austin Pizza Oven
  • Guerito
    • Sep 2007
    • 21
    #106
    Re: Kemo's South Austin Pizza Oven
    Hi Kemo,
    Obviously, by my number of posts, my ears are still wet, but I have to ask?
    With all due respect, what’s with the elevated pivot point for your measuring stick? Being new, this is the first time I’ve spotted an elevated center pivot. Does that elevate the “floor” to the top of your soldier course? Is that pivot point dependant upon, standing, or horizontal first courses? I’m not an engineer, so I’m learning by watching the masters. When I start my build I want to do it right.
    Inquiring minds want to know???????
    Guerito
    • Acoma
      • Sep 2007
      • 1023
      #107
      Is the final attached photo Mr. or Mrs Kemo?
      Acoma's Tuscan:
      • b_boyer2
        • Oct 2007
        • 1
        #108
        Looks like you have some good looking help there!
        Barney
        • Kemo
          • 215
          #109
          Originally posted by Guerito
          Hi Kemo,
          Guerito
          Guerito,
          I'm definitely no engineer either! But the idea was to have a semicircle starting at the top of the soldier course. Just like you mentioned. I was in fear of having my opening too high with semicircle on the ground, so I did the first course with the bricks up right to give a little rise to whole thing. If my theory is correct, this will create a higher dome and hold heat better with the size of my door opening. FYI, my opening is 20" wide with the begining of the arch at 9" maxing out at 11". Also, this is a 42" ID oven.
          Steve Kennemer
          Austin, TX
          • Kemo
            • 215
            #110
            I only recruit the best of the best for manual labor on this oven!!
            Shes not the Mrs, but shes the best thing thats come my way in a long long time... Ill do my best to keep her around
            Steve Kennemer
            Austin, TX
            • Kemo
              • 215
              #111
              Barney
              I have to agree...
              so when are we going to plan an oven for your back yard?
              Steve Kennemer
              Austin, TX
              • Kemo
                • 215
                #112
                Ok... Things are starting to zip up pretty fast here. These are the pics of work I got done over the 3 day weekend. Veterans day was a holiday at my workplace. I got some good work done during this time. My arch held up, I cant say enough good stuff about the REFmix. Hard as a rock.
                Steve Kennemer
                Austin, TX
                • Kemo
                  • 215
                  #113
                  and here is the last 3 pics, which puts me at course #8. BTW, I went to 1/3 bricks on course #7. Of course its at night and the pics are all grainy...but you get the idea
                  Steve Kennemer
                  Austin, TX
                  • Ken524
                    • May 2007
                    • 1655
                    #114
                    Yeah! You're making a lot of headway. Nice looking arch.
                    Ken H. - Kentucky
                    42" Pompeii
                    • rcspott
                      • Oct 2007
                      • 18
                      #115
                      Kemo
                      Would you mind explaining how the you use the stick as a guage? Do you use it for the radius of the brick circle, the angle of each brick in that row or both, or something else?
                      Rich
                      • Kemo
                        • 215
                        #116
                        Originally posted by rcspott
                        Kemo
                        Rich
                        basically, I use the line created by the bottom of the wood to determine how much mortar i use in the back. It creates the same angle between each brick all the way over the top. its centered and swivels 90 deg up and down and 360 degrees around in a circle. pretty neat tool built out of leftover 2x4 and a hinge
                        I hammer the brick down in the front and bring it flush with the course below it, right on the edge. so far its been a great tool. I fixed a smaller piece to hold the bricks in place since now they want to "slide" due to gravity.
                        Steve Kennemer
                        Austin, TX
                        • wlively
                          • May 2005
                          • 384
                          #117
                          Steve
                          You are really flying now. Keep up the good work.
                          Look out California and Canada, the Texans are catching up.
                          Wade Lively
                          • Acoma
                            • Sep 2007
                            • 1023
                            #118
                            Texans rarely see change in weather. You can go year round
                            Acoma's Tuscan:
                            • sarah h
                              • Sep 2007
                              • 567
                              #119
                              I can't believe just how fast you're catching up! Looks great!!
                              • Kemo
                                • 215
                                #120
                                the whole gravity thing is SLOWIN ME DOWN, YA'LL!
                                but here is up thru Course 9 currently at 1/4 bricks
                                Steve Kennemer
                                Austin, TX
