Kemo's South Austin Pizza Oven
  • Kemo
    • 215
    All,
    I have been lurking here for a while and finally jumped in and started on my oven!
    So far so good with only a few problems. I borrowed a shovel and a dirty hoe from a buddy of mine, he also lent me a wheel barrow (sp?).
    BTW, I'm a computer nerd and have never done anything like this before, so wish me luck.
    Below are some pics:
    DAY ONE - The Hole...and justification for wearing gloves.
    Steve Kennemer
    Austin, TX
  • Kemo
    • 215
    more pics...
    and here is Day Two after getting my brother-in-law in the action. He owns a masonry supply company in Houston, so hes a good guy to know I built the form, he put the 4ft level to it, and directed the rebar placement. We then mixed up 35bags of 80lb quickcrete by hand. Not fun. Apparently, I dug out too much and created more work. We tried to locate the 1/2" rebar where the drystack would be, so that it would tie into the slab.
    Steve Kennemer
    Austin, TX
    • asudavew
      • Jul 2007
      • 1880
      Re: Kemo's South Austin Pizza Oven
      Congrats!
      Off and running!
      Can you taste that pizza yet?
      My thread:
      My costs:
      My pics:
      • Kemo
        • 215
        Day three, Sunday, October 1st.
        This is what the slab looked like the next morning. not too bad and the level still said level. I banged off the form with a BFH and then went up to Lowes to pickup some cement blocks. Those things are cheap! I got mine for $1.29 a block. The angle iron for the front...not so cheap. Almost $25 for a 4 foot section.
        I had to make a modification to the layout of the bricks. i had originally planned to have a 60" inch frontal area based on a 36" oven + 9" for the firebrick and 5 inches of insulation on each side: 36+9+10 = 55. So I figured I would have a few inches of play room on the side. I totally forgot to do the calculations in 8" increments. Fortunately, I screwed up and ended up with the front of my slab right at 62.5". If you notice in the dry stack, I am just over the edge of the slab about 1/2". So, after all this, I think I will be able to actually make a bigger oven, which is a good thing.
        Steve Kennemer
        Austin, TX
        • Kemo
          • 215
          Dave,
          I can taste it!
          Steve Kennemer
          Austin, TX
          • Unofornaio
            • Jun 2007
            • 323
            Looking good.. and welcome to the group.
            If the pipes in the wall are for drainage from somewhere you might want to consider making a dry well for the water to go down and under the oven slab, caping them off or diverting them.
            Several tons of weight, stone wall corner, slab above surrounding grade add water from drains and you have...well, trouble.
            • Unofornaio
              • Jun 2007
              • 323
              woops too late now..you did all that while I was typing...wow
              • Kemo
                • 215
                About that wall there. I'm in a townhome and thats actually a retaining wall there. Behind it is a lot of clay and I high sloping hill. I havent seen anything come out of that hole except a frog! I think its probably clogged with clay. Its as dry as a bone in there.
                We had so much rain here this summer and none of the drains ever produced anything. There should be very little, if any water comming out of that hole. Even in the hardest rain.
                Steve Kennemer
                Austin, TX
                • asudavew
                  • Jul 2007
                  • 1880
                  Yeah!
                  It was quick!
                  My thread:
                  My costs:
                  My pics:
                  • Kemo
                    • 215
                    so my next step is to pour the concrete down in the holes. I probably wont get to it for a few days...
                    Steve Kennemer
                    Austin, TX
                    • Ken524
                      • May 2007
                      • 1655
                      That location is great. The pizza oven with the stone wall backdrop will look really nice!
                      Ken H. - Kentucky
                      42" Pompeii
                      • Kemo
                        • 215
                        I was thinking the same...plus, it came with the place (AKA - Free!)
                        Steve Kennemer
                        Austin, TX
                        • Kemo
                          • 215
                          #13
                          OK...day four here:
                          so I have filled every other hole of the dry stack with rebar in it
                          Steve Kennemer
                          Austin, TX
                          • Kemo
                            • 215
                            #14
                            and Day Five:
                            I had built the inner frame of the subflooring like so:
                            Steve Kennemer
                            Austin, TX
                            • Kemo
                              • 215
                              #15
                              and then after consulting with some engineer types here at work, I decided to add some more support to the subflooring on Day Six
                              Steve Kennemer
                              Austin, TX
