I'm halfway through curing my 50" internal oven and was wondering how much smoke, if any, one should expect out the door vs out the chimney. I'm guessing the hotter it gets (only at 300 now) the better it will draft out. I am concerned though in that my throat is as wide as my opening, about 19 inches, but the depth is only 5 inches. The chimney is an 8" one but it is set back a few inches over the dome opening arch. I'm wondering now if I should have not made it a full 8 inches past the arch or if this matters?
If so I could make some changes to the vent base which would be a pain considering it's a single pour/piece of concrete and rebar or I was thinking I could build a door with a draft option to block off the opening past the vent while firing or perhaps a metal cowl type addition that would come out a little farther into the landing and a little lower to catch and deflect the smoke.
I have a feeling I'm probably alright, just having newbie nerves haha but thought I'd ask the experts before I build or modify anything else.
Cheers,
Mongo
Cheers,
Mongo
Just a little humor, but the idea of extending the vent front and back sounds right.
