Hello Everyone!
I am building a 42" oven in Sac., CA. I have finished the hearth, set the floor, but I haven't started on the dome yet because I think I may have an insulation issue.
Let me try to discribe my potential problem. My square hearth is only one inch wider than the outside of my dome. That is, on the four sides of my dome, where it touches my enclosure, I only have room for 1" of insulation. At the corners, and up the sides, and on top, I have lots of room. Does this make any sense to anyone? If so, do you think I will loose lots of heat from these four spots that will measure about one square foot each?
I'm making the enclosure of used red bricks. When I drew the plans I figured the bricks would insulate. After checking out this forum for about a week, I realize that this might not be so.
Any advice?
Thanks,
Dusty as h*#$ in Sac.
Any advice?
Thanks,
Me being me, I would probably just go for it... But others will disagree.
