thinking of casting a vent to anchor plate transition out of the high heat morar I am using. It is called moldit x also called devils putty.
3 questions.
1. Is this morar suitable for casting this?
2. Should I drop in scrap pieces of brick into the mix?
3. Will the mortar heat up differently than brick so things dont heat up and
draw properly?......thanks wayne
3 questions.
