Sarah's Progress Photos
  • Re: Sarah's Progress Photos
    This may be a bit previous, but I don't think you've mentioned yet how you plan to finish your oven?
    Can't help on the cracks I'm afraid, since the materials I used are so different. I'm keeping my fingers crossed for you though...
      Frances, I'm not sure what the final finish will be yet - we'd love to retain the round effect of the dome but feel it could be extra work and perhaps a bit less structurally sound and weatherproof than building a 'house' around it.
      For winter though, I plan to get a blanket on it and we'll build what is at least a temporary structure out of metal studs and some sort of roofing material that can handle snow-load, then tarp around the sides when not in use.
      That winter protection can't come too soon though - woke up this morning to 8 centimetres (around 3 ") of snow!
        First, just want to say I hope all of you in the US are enjoying a Happy Thanksgiving, maybe even with dinner from your wood oven!
        Just a regular work day for us here in Canada and in my part of it, winter hit with a vengeance - only thing cooking in my oven is a heater. I'm pretty sure the moisture is gone but until I can give it one more blast tomorrow or Saturday, I want to make sure it doesn't freeze.
        Pics below of my poor oven - she'll get a nice winter coat this weekend. I have rescued the canopy twice from snow load - amazing it's still standing! I've used it for three years from spring to fall - it could fall down tomorrow and would still be the best $20 I ever spent!
        Yard cleanup may have to wait till spring.
          Sarah, thanksgiving in U.S. went great. Your brine recipe was perfect. I fill the cavaty with pieces of tangerine, apple and pear, seasoning, broth, brown sugar and syrup. I then smoked the turkey until 165 degrees. It was perfect.
          Acoma.
          Acoma's Tuscan:
            Hi Acoma,
            Glad to hear it worked out well. Bet that mixture you put in the cavity enhanced the flavour quite nicely!
              Yes indeed. Perfectly. Thank you for sharing.
              Acoma's Tuscan:
                Looking good! It looks colder there than it is here. What are you going to use for your door? I have looked around for a cast iron door but it is hard to find the right size. Keep up the good work!
                Thanks,
                Ryan
                  Ryan, it was -15C - 5F - when I got up this morning! This is way below normal for this time of year though, but the temp's on the rise today, to around the freezing mark this afternoon, then even better tomorrow. Have had a heater going and the dome was warm to the touch on the outside despite the chill (likely hell on the electric bill, but ...). One more fire, maybe tonight, then I'll be sure every bit of moisture is gone and it's safe not to heat any more.
                  As for the door - my neighbour had one made for me out of 14-gauge steel, with a handle in the middle. If you look back a few posts you'll see it there somewhere. I've found that if I leave it in place, propped up a few inches at the bottom with a brick, the fire burns really well. I'll be looking for a way to insulate it over the next while, and maybe decorate somehow too - right now, it's purely functional.
                  So, how cold is Colorado?
                    I've got to get a door built and try this Sarah.
                    Sometimes I think my fire isn't drawing well enough. I bet this would help. Still haven't quite decided how to build one..........
                    I'm sure it will pop into my brain one of these days.
                    So far I have just been blocking my doorway with leftover bricks in order to retain heat.
                    Thanks for posting
                    Dave
                    My thread:
                    My costs:
                    My pics:
                      Sarah, thanks for posting the photos of the cracks in the dome. I guess it's true that they all crack at some point. I also had a couple of small cracks in my clay flue chimney (both rear corners). I think setting it without mortar on the bottom where it meets the oven may have been better than mortaring it in tight all around. Who knows? Anyway, I put a metal band around the base of the chimney and tightened it with bolts like a giant hose clamp. (not too tight but enough to hold it together) I think it's fine but I opted for some cheap insurance!
                      Rick
                      View my pictures at, Picasaweb.google.com/xharleyguy
                        I am curious, if we are seeing numerous cracks with the ovens during cures, why not go straight to insulation wrap and Matrilite 18 to seal it. Once this is done, then do some fires? Wouldn't this keep the expansion under better control for cracks? Just wondering.
                        Acoma's Tuscan:
                          What is Matralite 18?
                          Steve Kennemer
                          Austin, TX
                            It is some kind of insulating mixture/covering... waterproof i think... and I believe that Canuck Jim uses quite a bit.
                            There are a few posts about it. I will see if I can find one for ya Steve.
                            My thread:
                            My costs:
                            My pics:
                              Dave and Kemo, Jim talked about the uses of Matrilite 18 on this thread:
                              I suggest you use it. You can go max on insulation as I mentioned earlier with what I will do. Talk about long term maintained heat levels.
                              Acoma's Tuscan:
                                There hasn't been much to post lately and the season seems to have me busy with 40, 000 other things too but there have been some little bitty baby steps of progress ...
                                We started on a steel stud frame - it really IS there in the pic below (gotta open it to see the snow flakes falling last night), but under the tarp, which doesn't look as though it's coming off any time soon. The weather is keeping us from moving ahead so I had to settle for baking in the regular oven (second pic, though it may be cheating a bit to post a baking pic from a regular oven).
                                The biggest thing though is that I now have a thermal blanket (Canadian supplier & fairly close, which really simplifies things in many ways; otherwise I would have ordered from FB). Unfortunately, it's still in the box (third pic), waiting for a window of opportunity to open so that I can get it put on the dome. Hard, when I can hardly find time to scan the forum these days!
                                Hope everyone's holiday season is shaping up nicely!
                                Hope I have more to report soon!!
                                Sarah
