Re: Reinforcing arch sides?
I'm kind of kicking a dead horse 'cause Ken's already solved his problem, and it looks like a great solution. Sorry to run over your thread Ken. Perhaps more comments might further enlighten other builders as to the need for extra support in their respective situations.
I'm copying Ken's entryway arch setup (though it won't look nearly as good when it's done). I was thinking the same thing about needing extra support, especially since I was planning on placing a cast vent on top of the arch, which will ultimately attach to a Duravent system chimney. My casted vent weighs a lot..... probably 30 - 35 LBS. Also, I need 7 - 8 feet of chimney to get above my adjacent swimming pool enclosure. That's quite a bit of weight, huh? Am I expecting too much out of the arch? (Pic attached - note the highly technical use of a stepstool to hold the arch form at the correct height).
I read up on stone arches online. From my limited understanding, all the forces of the weight of the arch are transferred laterally, and thus, the reason all the great ancient arched walls had a ton of butressing.
Based on this, I would thing the majority of the stresses would be in the upper couple bricks and mortar joints of the walls, and would be the likely area of failure due to overloading the arch. Wouldn't you then think that additional buttressing would be most useful in the upper levels of the entryway/vent walls, or at least more important than the lower walls??
Sadly, Ken's/France's solution will not work on a my corner installation oven, as there is no place to mount the brackets.
Thanks for any comments.
George
George
