#16
(M) The Step by Step instructions do not seem to agree with the photos. The instructions say:
"The first chain is a ring of brick cut in half and standing on their ends, with the thin edge (2 1/2) facing inside the oven. You can adjust the exact diameter of your oven to match the size circle that your bricks form, so that you do not have to cut a brick in your first chain.
(M) This is not clear to me. Do I cut them to 4.5 x 4.5 x 2.5, or do I leave them UNcut at 9 x 4.5 x 2.5 ?? ____________
"The subsequent chains are made up of brick cut in half and set on their wide edge (4 1/2") with the clean edge facing in."
(M) I see 2 accompanying photos. One surely looks like a full soldier; the second, like his little brother. Please look at the images, below and kindly clarify.
Thanks,
Ciao,
Marcel
Thanks,
Ciao,
Marcel
