Forum Notice: The forum has been upgraded and restored to November 2. Posts and new accounts created after November 2 were lost. Sorry for the inconvenience.
Well, now you will hopefully have no issues with cracks Good luck.
Thanks Robert. Today's fire, the first, was very small and brief - almost seemed like it didn't do anything. When I stuck my hand in there, it was hot, but it was the kind of hot that you would get from sticking your hand next to any fire. Half an hour after the fire went out, the top of the dome wasn't even warm inside. I will let tomorrow's fire burn a bit longer and so on.
Batten down the hatches and stay safe this weekend. From what I'm hearing you may have to go outside and shake a bunch of snow off of that tent. This one is supposed to be packing quite a punch.
Dusty, you cleaned the inside of the dome very well. Well, now you will hopefully have no issues with cracks, just good cures, then insulate. Good luck.
Robert
George, I was laughing when I saw the prior to curing pic. Forget the smooth cladding, go mountain terrain style. Maybe a ski chair leading to the top, some people jumping on the bumps
yeah, we were laying it on thick, not believing that those bricks were going to stay up there without a little extra goo.
Cool keystone Dusty. I hope you dispatched a salmon with it (bonk on the head) prior to setting it.
G.
Yeah, I have been back and forth on that a bunch to the point of procrastinating. I decided to take Ken's lead, found 100 sqft of Kaowool 1", 8 density, blanket in Milwaukee for $130. So my plan (unless someone here has some better thoughts) is to get my thermocouples in place, wrap it in the blanket, tie down with thin wire anchored to the vermicucrete (that will be easy to remove). Go through the curing fires and when I think all is cured, remove the blanket to inspect the cladding for cracks. Now, I say that having zero experience with handling kaowool pre or post heat applied. But in asking the supplier he thought it would go back in place after inspection with little difficulty and in the same fashion as first applied.
Good to hear from you Big Dave... and thanks for the kudos. Much appriciated. Glad to be done. Looking forward to borrowing a few of those reciepies and tecniques from you soon.
Looks like the party, if you can call it that, is at the Cabana club ( hokie li' swim and tennis club in our neighborhood). Probably be about 10 - 15 of us sitting around the fire pit tellin' lies and stuff. Bought the celebratory pack of the good stuff, PBR's, since it is a special occasion. At midnight, we set off a couple of model rockets packed with explosives and then off to bed. Kinda slowin' down a bit in my old age, but haven't completely stopped yet!
I suppose you're firing up the badWoFo right now. Have an ice cold one for me and Happy New Year to you and your family.
Thanks for your input Goerge. I agree with you. Plus, my mortar joints are very small. Few are larger than 1/8" and most are smaller than that. The lower 3/4 of my oven LOOKS dry - that is the bricks are dry and the mortar is light grey. the top looks dry on the outside but the mortar on the inside is still a bit darker in color. I plan to figure out a way to start curing it this weekend. Meanwhile, I need to decide what to do for a chimney.
You are relentless! Stealing away on Christmas to cap the dome? and now the arch (which looks way cool by the way). My keystone ceremony was just me and my wife but still the milestone moment, one where you no longer measure your worth by how many courses (or parts of a course) you were able to get done in a particular session. I have actually taken the last couple weeks off from the project, as I wait for my new theromcouples to arrive (replacements for the ones I misordered). Then it's insulation and curing fires.
Congrats on your oven, it looks great. Can we get your photographer to take some inside shots?
Dusty,
Good question about the electric heater. I figuring that only the work done on the keystone needs a week of curing, which would be New Years Day. Presumably, the keystone didn't really have much of a mortar joint anyway, so even if you weakened it a bit by getting it warm too early, the keystone is not going to fail, and fall to the floor.
The previous rows were done prior to that, so need that many fewer days before you can light a fire or use a heater. Most of the work has already had a week to cure, so for the most part, you're pretty safe with the electric heater.
I waited six days and then used electric heat. It only got to 120ish degrees in there, which is not a hell of a lot hotter than the occasional Sicilian and Southern Italian summer days. Somehow, their oven work survived the temperature extremes, so I figure that mine was pretty safe.
A couple of days with the heater made absolutely no difference in the mortar joints that I could see. My soldier and first three courses still showed moisture lines on the cladding, even after the first four or five curing fires. I covered the dome with insulation before I ever saw them disappear. Here's a pic from prior to curing: http://www.fornobravo.com/forum/atta...gress-fb29.jpg
I was worried about freezing temps and wet mortar and so used the heater. If that is not a concern for you, the heater is probably a waste of time, though it may help minimize the thermal shock to the mortar joints by running it for an hour or two prior to doing your curing fires. I can't imagine that going from 40 degrees to 300 degrees in a matter of minutes does anything good for the mortar joints. 120 to 300 just might be a bit easier on them.
If you get a few days of clear skies after the 1st, it might be worthwhile to get out there and get curing. Otherwise, you're probably very safe in waiting till Spring.
My understanding of the oven curing is that you need to wait at least a week for the cement component to cure, and during that time the dome should not be allowed to dry out, or to freeze. That bit of curing is just like for regular cement.
And after that you need the curing fires, beginning with a small one, and slowly working up to a big one, to get the dome used to being heated up to pizza temperatures without cracking.
But I don't really see any reason why you shouldn't be able to wait for a month or two before starting the curing fires...?
BTW, your archway looks really cool Dusty, I look forward to seeing the special keystone!
