Dutchmen everywhere .. some with questions
Hi Guys,
James: with regards to the $25,000 pizza oven: I'll take a picture of it and post it on here.
And yes: I'd be more than happy to refer your products to people here - hell, I could become your NZ representative... but then again, total population of NZ is only about 4 million, so that is a pretty small market. And Kiwis are inveterate Do It Yourselfers. (supposedly a Kiwi can fix anything with a piece of no.8 wire)
There are indeed a lot of Dutchmen here. The bulk of them came after the second world war. I came here 25 years ago, chasing a kiwi skirt...
And there are lots of Dutchmen everywhere, including the US. Hey: New York used to be "New Amsterdam" you know...
Marcel: My *real* name is actually Peter. (not that I mind a helluva lot..
Now for some more questions:
I went and saw my fire brick supplier about the type of bricks I am getting. They are 9" X 4.5" X 3" with about 37% Alumina content, so should be good, from a thermal point of view.
He suggested I shouldn't be using refractory mortar between the bricks, but rather refractory concrete ("castable"). He reckons mortar is only good for gaps between bricks of a 4-5 mm. (just over 1/4 inch) Because the bricks are going to angled on both the horizontal plane as well the vertical, the gaps will be (much) wider than that.
Also he reckoned I would not be able to cut the bricks with a skill saw with a diamond blade, because they are way to hard. He would allow me to use his big industrial saw to cut them, but at a cost of $1.50 per cut... !!! (Dutchman getting very sensitive now
Is it really that hard to cut firebricks?
Anyway, I am going to be buying a grinder with a diamond blade, and see for myself...
Hi Guys,
