#49
(M) I'll be closing my dome tomorrow, if it doesn't rain, and want to start on my chimney. I will probably use neither a steel nor a clay liner.
(M) My question is, given a builder's choice is to use only brick for a flue-chimney, would it be better to use insulating brick or firebrick? ___
(M) I can see advantages to both but those plusses are predicated on assumptions of whether stored chimney heat will help maintain dome heat, or whether a chimney inherently gives up heat with the smoke.
(M) Thanks to anyone how contributes their perspective. If you see a post which refutes your position, pipe in anyway. I'll tally the thermals and the insulators.
Ciao,
Marcel
Ciao,
Marcel
