My oven cracked during our first firing (not a hot enough to burn the soot off fire) after more than a week of curing.
NBD, I think, because everyone has said that their oven has cracked and will crack. YOu could literally see the moisture along the crack lines. But my concern is twofold... how much is too much?
1) the dome is quite sturdy, but it cracked enough to let smoke out.. also it cracked all around the oven showing fracture lines front and back... when I patch, do I use the same mortar and do I worry about the structural stability in the long run?
2) my front archway, which will be covered up was only a few days old, so it cracked enough that I can probably lift out the keystone... that's just a lesson learned about rushing the heat..
Do I have to start over? *snif*
. Really, I dont believe there is much to be concerned with as long as bricks are secure.
) and plan to do so again at full burn before we insulate the oven. Seems to work well.
