Gang,
Starting to get supplies (already got the FB blanket, Heat Stop 50 and scored some "red" fire bricks for a few courses) ready.
Just a few misc questions as I plan the build.
1) Is the angle iron necessary over the front span? I was just going to build a form with wood and rebar and pour a 4 inch hearth. I want to get as much "headroom" for my wood storage opening as I can? My spane is about 30" wide.
2) After cutting the bricks in half - does in matter which side faces the oven interior - cut side or the uncut side/reason?
3) When placing the bricks for the hearth I saw some posts about using a dry mixure, then setting the bricks, then wetting it down. Anyone done this yet/do you just pour a tone of water down or what? I guess I want to get a smooht surface but I've read I can just sand it down - this sanding wouldn't impact the longevity of the oven floor would it?
Thanks so much in advance,
Dick
thebadger
Dick
thebadger
