Re: 48" oven about to start, need advice about buttressing
This reply had to be split up because of the limit of the number of images.
Here's an oval shaped low dome oven section, showing two buttresses on either side of the dome. I can't easily draw a catenary curve in my cad, so you will have to imagine it. You can see the forces are spread out, bearing down on the brick floor, instead of pushing out on the side walls.
I would envision six buttresses, two of which would form the side walls of the entry door. For the sake of simplicity I've just shown some bricks leaned up against the side of the dome. It would be much more sound structurally if these buttresses were tied into the first courses of the brickwork.
As Johnrbek said above, this is strictly theoretical. You can take it or leave it. His solution to the problem is a good one if you can find a castable refractory insulating material that is also structural to the extent of being able to be reinforced with rebar, and to withstand the huge forces of a unitary dome that's hot on the inside and cool on the outside. I'm interested to hear exactly what this material is, and to see some specs on it, but in the meantime, I think my solution is one that would work with minimal mass and traditional materials.
Sorry to be so long winded in my reply. I hope I've explained what I'm talking about.
