Cutting Isol
  • thebadger
    • Jun 2007
    • 383
    Cutting Isol
    Gang,
    Just got my Isol Board!!! Thanks Valerie at FB.
    How do you cut this stuff? I'm assuming a standard jig saw with the corse wood blade? I'll wear Glasses, gloves and a respirator mask of course.
    Let me know.
    Dick
    I am pouring a 3 1/2 thick perlite/cement layer first - mainly to bring my hearth height up. I know it's overkill but you can't have too much insulation
  • PizzaJNKY
    • Mar 2008
    • 159
    Re: Cutting Isol
    Hey Badger, I'm right behind you. I finished my perlite/cement layer yesterday, and am waiting for my isol board. Should be here by next weekend. I was hoping I could cut it with a dremel tool, but not sure yet if it will work.
    "Pizza, the world's most perfect food."
    • Les
      • Sep 2005
      • 2945
      Re: Cutting Isol
      I used my saws-all. I would think that just about any saw would work. The product is not hard to cut. It makes dust like no other
      Les...
      • thebadger
        • Jun 2007
        • 383
        Re: Cutting Isol
        Les,
        Thanks.
        DUMB, DUMB question? I guess it doesn't matter which size goes up, right?
        Dick
        I'll try my jig saw...
        • Les
          • Sep 2005
          • 2945
          Re: Cutting Isol
          I used a product called insblok 19. If I recall, one surface has a little smoother finish than the other - I put that side up. It doesn't matter - it's the same material all the way through.
          There are no dumb questions, except the ones you don't ask.
          Les...
