HELP - What type of Castable for Vent?
  • thebadger
    • Jun 2007
    • 383
    My brick dealer is placing an order and can add some castable material from the manufacturer on the order. My question is what castable should I buy for my vent...
    Needs to hold 8-9 feet of duravent
    Will have to cure in place
    I was thinking of the following:
    KS-4 Plus
    PacoCast
    Heat Cast - 40 (same company that makes Heat Stop)
    Fast replies would be appreciated...
    Dick
  • wlively
    • May 2005
    • 384
    Re: HELP - What type of Castable for Vent?
    I used KS-4, cast in place, and cured in place. KS-4 is very solid and easy to work with. No problems. I would not only use it again, but would proabably cast my entry and event in one piece if I were to do another one.
    Don't forget the stainless needles.
    I posted a couple of picts a while ago. Search vent casting and you should find them.
    Wade Lively
