I've had a look round the forum and tried search, but can't find any references to this idea - there's a mention of tapering bricks in the plans pdf, but nothing in the appendix as suggested on page 31...
Does it make sense to cut your firebricks to fit the dome ?
i.e if when you lay out the bricks in the dome shape (cf page 9 of plans pdf) you see that there are e.g. 11 bricks between the first soldier-brick course and the final vertical brick, that means there are 12 gaps and a 7.5 degree angle between them all. If you then cut the bricks in half at this angle rather than at a right angle you can lay each course without the use of shims.
This means that there is little mortar (if any) used in the horizontal joints - is this a good or bad thing ?
A further refinement would be to also cut one of the "vertical" edges of each brick at the appropriate angle (changes for each course I think) so that they all fit together - this would use more bricks in each course, but less mortar and might look strange from the inside with a sort of spiral effect to the brick work.
Has anyone tried this or is the idea completely stupid ?
TIA Roger
TIA Roger
