Hi. This is my first post. I think I have done well to this point, but have hit a roadblock.
I am ready to pour the concrete base which sits on the cinder block stand.
It is a corner build. The base will be cantilevered 18" on the right and 12" on the left side and will curve in the front.
I believe I have enough rebar support throughout.
This project is in Massachusetts and I am hopeful that the weather (falling temperatures)is still going to hold out for a successful pour/cure.
What is the best concrete mix/ratio to use? I intend on using insulating fiberboard above the base/below the hearth so I am not anticipating using vermiculite.
All suggestions/ideas/concerns are helpful.
Thanks in advance.
David G
Thanks in advance.
David G
