Question about pouring the hearth
  • jas0ny
    • Dec 2016
    • 53
    I am at the stage where I finish building the block stand. My question, is there any requirements as how deep the hearth foundation has to be if i would like have the FB board flush and recess to the hearth?
  • RandyJ
    • May 2010
    • 1191
    I am unclear as to why you want to recess the FB board? You do not want it to be down in a sump. It is likely to collect water and be very hard to dry out after the oven is done. Also most need to raise the oven above the support slab to get the height they want.
    Randy
    • jas0ny
      • Dec 2016
      • 53
      thanks for your reply randy i was looking into something like this i found that a member did. My reason is i dont want the cooking floor to be elevated so much from the hearth itself. I dont like how i would have ceramic board that is 2" then 2" of cooking floor. I would like the look of just the cooking floor.
      • jas0ny
        • Dec 2016
        • 53
        I am trying to achieve this flush look.
          • 9215
          If doing it this way, all the more important to have some holes through the supporting slab to provide an exit for moisture. It is easier to cast them when laying the slab rather than drilling later.
