I’ve laid down the insulation layer using Perlite mixed around 5:1. It took quite a few days to start to set, now it’s been a few weeks it seems pretty solid, lots of air pockets I didn’t count on while laying, basically was a bit hesitant to push down too hard in order to avoid the stuff breaking up too much but maybe the air pockets will insulate anyway.
I’m off to get the fire bricks, they’re 230mm x 110mm x 75mm, the 110 worries me a bit, should be 115mm hope it won’t throw out my layout, also says he supplies glue instead of high heat concrete, says it doesn’t crack under heat. My sister had one installed and they used glue too but it was one of those pre cast kits imported from Italy.
I’ve allowed dome thickness of 250mm being 110mm fire brick, 50mm blanket and 200mm brick render.
Made my IT and used it to scribe out the base template, internal diameter is 1060mm (round 42”).
Having trouble uploading photos at the moment, keep getting upload failed. Maybe images are too big ?
