Well its started !!
After leaving the base to settle (!) for about 5 months, I've been finishing the insulated hearth and rendering the walls of the base today.
Due to space, I'm looking at about a 31" hearth on a corner install. The final design isn't finished, but SWMBO wants a 'brick looking oven' rather than an igloo, so it will probably end up clad in a brick skin ( so it will look like a brick igloo instead.... )
Walls are all 4" thermalite blocks, on a 8" plinth. The hearth is 4" of reinforced concrete with rebar set into the walls, and 3" of vermiculite concrete. I've no idea what happened, but the vermicrete didn't want to hold together, so today its had a dry sand and cement binder layer with 4" thermalite (AAC) blocks over the top.
Bricks for the dome are coming from Martin (Thanks ! ) and his recent eBay win, and I'll be cracking on next weekend as long as the weather holds !
Oddly enough, both my neighbours have WFO's - one is a sort of adobe style, the other is a precast from Purimanchos. Wonder if we'll get some oven-envy going on !!
I have to say, this forum keeps me going - the help and advice is always available !
Cheers
Peter
Cheers
Peter
