Insulation under Base
  • mike361
    • Jun 2015
    • 4
    Hi All,
    I built my 36" oven 3 years ago but have neglected it due to my wife having our twins,
    Now they are a little ones are older i am now keen to start using it.
    when i built it i stupidly didn't insulate under the base of the over so when i touch the underside of the concrete i feel it warm.
    Do you think i could just insulate it from underneath as i'm not willing to strip it all and start again?
    Mike
  • rwiegand
    • Oct 2011
    • 191
    Can you pull the floor bricks out and add at least an inch of insulation underneath? You're fighting a big heat sink with the concrete slab. Putting insulation underneath it is better than nothing, but probably won't really help your floor temp much.
    My build thread: https://tinyurl.com/y8bx7hbd
