Originally posted by RandyJ
View Post
36" Pompeii Dome Chicago
My Build Pictures
Yes that is exactly the problem i run into as well. I have gotten to the point where i can do pretty much anything around the house, and i can do as good or better than hiring someone that may not take pride in their work. As you know if you get stuck on a project at home all you have to do is go ask another tradesmen how they would handle situation xyz and they will generally tell you what to do. Or now you can just Google it. I am guessing that i will end up building myself to save money
I couldn't have said it better myself.My Build Pictures
My limestone arch and chimney cap were ready for pick up today so I installed them both. Finally no tarp on the chimney or anywhere on this structure. Chimney pipe finished storm collar installed . Limestone arch set and installed and I am very happy and received a "that looks fancy" from the boss! Today was a good day and I'm on the road to the end.
RickyMy Build Pictures
- 1 like
Fancy Indeed! Funny- I clicked on the first pic and thought "Oh, Chach has a legend inscribed on his oven". Then I read "Wonderboard lite"My build thread
Originally posted by JRPizza View PostFancy Indeed! Funny- I clicked on the first pic and thought "Oh, Chach has a legend inscribed on his oven". Then I read "Wonderboard lite"
Originally posted by RandyJ View PostI like the limestone arch. It looks very nice. What do you have going on with the strut and angle brackets. That seems like something i might do. Does it anchor the bottom to the oven? I can't wait to see the finished product.
Randy
I hear you there. I normally like to over support things. I am sad i an no longer at the paper mill as we had lots of scraps of SS strut and that would be awesome as you would never have to worry about it rotting away.
As a side note i ordered the concrete and block for my base. But one of the patio guys i had come over said he would poor me a 8" slab with 5 peir supports and rebar in matching color to the patio for 200$ not sure i can pass that up. But would not happen till close to june unfortunately but would look more cohesive.
I also finished grouting my shower in our Master bathroom and milled the window jam extension and got them all installed and stained and polyurethaned and the trim on. Finally getting close to done. Now once everything opens up again I just need to get the wife to agree on a counter top for the vanity and that can be done. I hope you are keeping busy and safe.
Randy
Originally posted by RandyJ View PostI hear you there. I normally like to over support things. I am sad i an no longer at the paper mill as we had lots of scraps of SS strut and that would be awesome as you would never have to worry about it rotting away.
Randy
RandyMy Build Pictures
Yeah the guy was saying that the patio and slab would be separate from one another and that he has worked many times with a guy that builds outdoor fireplaces and the weight is about the same. So i am tempted to go with what he is saying as it sounds correct. He also has a awesome rating in all his reviews. As you know it is hard to find a contractor that has that. Also with having the patio dyed it would be nice to have the color the same so it doesn't look funky. I just don't want to have to do this over again so trying to do it right the first time.
Randy
Finally some nice weather no rain. I was avle to make some progress on finishing up this project. Stone work is going up faster than ever. I'm starting to see the light at the end of the tunnel
I was able to continue working on the stone. Doing a Dry stack looks so much better than having a mortar joint but sure takes a ton of time. I have the whole front and whole back 100% done. Hopefully I can finish the 2 upper sides tomorrow. Happy I was finally able to set my custom engraved stone.
RickyLast edited by Chach; 05-09-2020, 06:25 AM.My Build Pictures
