It seems to me that most ovens are built without a thermal break between the dome and the outer entrance area. Mine will be a 42" Pompeii.
My dome will be housed in a brick (dog house) type shell. It will have 4" of perlicrete under firebrick floor.
Should I worry about it or just lay it all up solid?
after the concrete was hard I filled the break with a portland/vermiculite mix, as as I put under the slab. Probably little difference either way it just made me feel better.
