42" build in McPherson KS
I was trying to describe the final product to my wife and she told me to just draw a picture.. Here's a very rough sketch of what I'm going for..
- 1 like
thanks SableSprings. In places where the hearth is flush with the CMU wall I plan to stucco so it looks like a continuous wall and I will pour a countertop on top of that. On the side where the hearth juts out from the CMU wall (the oven side) I haven't decided if I will pour a countertop or if I will try to stain/polish/finish the hearth itself to give it more of a two-tiered look.
The gaps in the concrete edges (along the forms) are fairly common...that's why you see folks tapping the forms during and just after a pour.The tapping settles the concrete and the air gaps get filled in. The issue is very minor in terms of your slab strength and utility. I tiled the outside of my foundation stand and simply filled in the rough spots along the top edges of the platform top with mortar or thinset...which ever was handy at the time. I suspect you had planned to finish the outside of the CMUs and it could be covered up at that time. Otherwise, simply make up a batch of mortar and fill/smooth out those areas. Relax, it's looking good (and very normal!)
- 1 like
Removed my forms. My edges didn't come out very clean in a few spots. Can this be filled in with something?
Originally posted by david s View PostGlue some insect screen over the holes before you lay up the vermicrete. This will prevent it falling through the holes.
- 1 like
UtahBeehiver I am hoping to build an external brick dome around the oven, similar to cobblerdave's oven.
So with 2" of ceramic blanket being the bare minimum around the dome, does the same go for 4" of vermicrete under the floor? should I be increasing my floor insulation as well?
2" of ceramic blanket is your minimum amount, if you add 2" of 8-10 to 1 p/crete then you are golden, skim coat with render and then final coat of choice.I cannot recall if you are enclosing or not. If you were, I would do 2" of ceramic blanket then fill the enclosure with dry perlite or vermiculite.
- 1 like
UtahBeehiver Yeah, I think Saturday was sort of my last hurrah before winter, though we usually get a couple warmer weeks during winter that I might be able to take advantage of... However, I will be taking a break to rethink my oven size...
I think I may be able to increase my dome size a little bit now that I have the overhanging hearth. I will be using 9 inch firebrick (split) for the dome. I am trying to get an idea of my overall final "dome wall" width so I can decide how much extra I really can expand. Is 2 inches of FB blanket a common/adequate amount of insulation? I keep reading that you can't over insulate, but I am just curious what is the most common insulation width on the dome. Maybe 2 inches of blanket and then 2 inches of vermicrete?
Nice work. I see your leaves are turning so your construction season is coming to a close. Look forward to seeing the rest of the build when you resume.
Poured the hearth on Saturday. I want to leave my supports under my block beam until the first or second week of November, then I will get under there and poke some rebar back up through my pvc weep holes. Once they are poked through I will be able to see them from the top and will form a little bit of a mound between them before I put down the vermicrete layer.
no real standard but couple in the dome foot print should be fine, 3/8" or 1/2", some members fasten a piece of wire mesh on the bottom side afterwards to prevent bugs nesting homes. You can also use some pcv and place top just below top surface of concrete hearth (so you can screed) then just knock out the thin top from underneath with a piece of rebar after the pour.Last edited by UtahBeehiver; 10-19-2018, 07:04 AM.
- 1 like
I just finished framing the hearth. Going to pour on Saturday. Between now and then I'm going to drill some weep holes. What's the standard diameter and placement of weep holes?
This is the correct way to do lintels, much better than trying to hold it up from the bottom with angle iron. Next time put some wedges under the uprights so they drop a little to assist removal, otherwise you risk damaging the poured lintel.
- 1 like
The concrete seems to have weathered the storm.. Solid enough now that any moisture is good moisture...
- 1 like
