Curing fire
  • LeeBird
    • Sep 2018
    • 13
    Curing fire
    I have finished the dome, fire brick and refractory mortar. Waiting to insulate until after curing fires. Question: how many days do I wait between setting last brick and starting fire?
    • 5260
    Lee, current thought is to have the dome insulated before cure to min. Temp differential from inside to outside dome. Then final render after cure
    • LeeBird
      • Sep 2018
      • 13
      Thanks Russell, that makes perfect sense. Do I need to wait and give the mortar time before lighting the fire?
        • 5260
        You could start with a halogen shop light, gets you around 125 - 150 f(now) then charcoal 200 ish (cook something, dutch oven or so), then fires. Back tomorrow will text you abt insul.
