fire clay vs heat stop
  • fire clay vs heat stop
    Cant Seem To Find Fire Clay For Under Oven Floor ,any Suggestion If I Can Use Heat Stop To Level Floor,cant Wait To Start Building My Igloo.any Help Appreciated,
    Re: fire clay vs heat stop
    Sure, you can use heat-stop. Put the powder down dry, just enough to cover the lumps in the vermiculite concrete, lay the brick floor, and when you're happy with how the floor is lying, wet the brick floor to set the concrete.
    The only advantage to the fireclay-sand mixture is that it's much cheaper than heat-stop.
      I didn't use any fireclay at all. I layed insulation board on the perlite/portland insulation hearth, and the board went on level. I just layed my bricks ontop of the boards.
      "Pizza, the world's most perfect food."
        what kind of insulation board did you use?sounds like a good idea -nice and level--In ny cant seem to find what i need --hd always out of stuff-lowes dont carry what i need -slows the progress-weather no help-but enjoying the build-first time mason work-cheers-
          Mikipal, I ordered the FB Boards from Forno-Bravo. They are fantastic. Even though my perlite/portland hearth was rough on top, the boards went on nice and level. A perfect floor for the firebricks, and much better insulation than perlite/portland alone.
            I agree with Pizzajnky
            I put down a 3 1/2 of perlite base mainly to raise the hearth level then the 2 inch Isol board on top. Even with the Iso board I had to level the bricks a little. I couldn't imagine trying to put the bricks down on the perlite/concrete it was very uneven.
            THanks
            Dick
              I used Perlcrete.... then I poured about a 1 inch thick "slab" of high heat mortar on top. (poor man's)
              It was nice and level.
              But I love the idea of perlcrete followed by insulating board.
              An oven can never be insulated enough. IMHO
              My thread:
              My costs:
              My pics:
