Dan,
Mike brings out some good points about metal roof condensation. We call it "sweating" down here. But first::
I just wanted to note that there must be horizontal lathing installed to which the metal roof is attached. You probalbly knew that, but I have to be sure. The sheathing that Mike describes would take care of that.
Down here, insulation under the metal roof is installed to limit the sweating. I was wondering if you are going with metal or wood framing?
I had planned to lay the corrugated sheets right over the framing of the roof (rafters every foot).
). Even though your roof area will be relatively small, possible "snow slide" still should be incorporated in your planning.
Also a bummer to not have a bit of covered work space to prep a pizza or to set down a finished one. If you can do a slightly flatter roof, you can extend farther out on the sides to cover you and your prep table...just another random thought
