It will be easier for the oven to cure without the vermicrete/perlcrete outer layer. Be patient and continue reasonable fires as long as things remain damp. A great tip from David S is to lay a piece of clear plastic over the oven and if moisture is still being driven out, it collects on the inside of the plastic and you know that you need to continue the curing process. The cooking floor is always the last to be cured with the moisture tending to be more "trapped" in the base insulation board and bricks...BE PATIENT!
Relax, you've done a good job and have a working oven...you are now into the finesse part
...enjoy an adult beverage with your items hot and tasty from the WFO.
