OK, I'm going close in my dome and work on my entrance this weekend. I plan on using clay brick for the entrance arch and chimney (I think). So, should I use firebrick to make the vent transition or are regular bricks OK to handle the heat? I've seen it done both ways here on the forum and would guess regular brick is fine, but it never hurts to get opinions.
I had also planed on using a clay liner with a brick facing for the chimney, but I wonder if the liner is really necessary given the use (outside, away from combustible materials, etc). Thoughts?
Last question, what about mortar for the entrance and arch bricks? Refractory mortar, right?
Thanks for any guidance...
