Hello,
my name is Jens and I’m looking forward to build a first Pompeii Oven this summer. I read the plans version 2.0, watched a lot of Youtube videos and checked this forum, but now I have a few questions, where I could not find definitive answers for. I want to draw plans and calculate the size of the foundation, so I need to know what materials I use.
Greetings and thanks for your help!
Jens
- Hearth: Is it better to use a ceramic isolating board or isolating concrete?
- Hearth: Is it better to construct the island hearth for additional thermal mass or will this get to massive? There will be occasions once a year, where I will make pizza or cook for about 50-60 people. But most of the time, I use it for 4-6 people eating a pizza/making some food or for baking some bread for me and a two neighbors.
- Dome: Should I apply an addition 2“ of high heat mortar around the firebricks for additional thermal mass (see question 2)?
- Oven Dome Insulation: I want to use ceramic insulating blanket as this seems to be the more modern option. The outside of the oven will be finished with small tiles. How do I construct this? If I put a 3“ layer of the blanket on the dome, this will be soft, so the tiles will fall off. Do I have to build a vermiculite layer on top of the blanket first in this case? How thick is enough to give the outside enough stability?
- Weather: What product / color / material is best to protect everything against water? Do I have to put a waterproof layer of color directly on the vermiculite? I didn’t get the idea out of the english manual, sorry…
Jens
