Does anyone UK based have a cost for building an oven?
So far I found a 2017 thread he halved the cost of the concrete by buying concrete in base components.... bulk sand, bulk aggregate and bags of cement. Works out MUCH cheaper, essentially half the price. I would need a foundation which he didnt need.
Foundation:
Fortunately I already have a concrete slab as a foundation.
Base:
As per the guide, I’m planning to stack up hollow concrete blocks to make my base and pour concrete down alternate cores.
Hollow concrete block construction. 70x blocks @ £2.40 = £168
Concrete 25kg readymix bags 15x bags @ £9.36 = £150
The concrete seems outrageously expensive- I thought concrete was supposed to be cheap?
Cooking Surface:
A 9cm thick, steel reinforced, concrete slab with a further 9cm thick vermiculite concrete on top.
Sand/cement to lay down underneath firebrick cooking floor.
Concrete block 1.2m x 1.2m x 0.2m. 25kg readymix bags 30x bags @ £9.36 = £300
Vermiculite for insulation in concrete top layer. 100litres= £18
Firebricks x60 @ £1.60 = £96
Rebar for concrete ½” x 9m = £51
Sand 50kg = £5
Portland Cement 50kg = £10
Again the concrete is killing me here….£300!
Dome:
Firebricks x 120 @ £1.60 = £192
Procast 1400 castable (25kg bags) x4 @ £18 = £72
Chimney:
£30 steel stove chimney, with covered top, from eBay.
Insulation:
Ceramic fibre "s" blanket 38mm 128kg x1 = £60.00
Vermiculite 100lites = £18 (don’t know if this is enough?!)
Rendering…. Not priced up yet but dreading it based on the above.
External plaster/render
Wire mesh + rebar
So far the price of the above is £1088
Foundation:
Base:
Cooking Surface:
Sand 50kg = £5
Dome:
Chimney:
Insulation:
Wire mesh + rebar
