Help with Finishing the Dome (Build #2)
  • thebadger
    • Jun 2007
    • 383
    Hi All,
    Working on rebuilding my first oven due to water issues...
    For the original build I believe I put a skim coat of Portland cement (I don't think I used and actual stucco) over the perlite insulation. I then painted it with a latex paint.
    For the Rebuild I am grinding off the original paint (you can see the before and after pictures below) and am going to use the "Stuco-Flex" brand elastomeric stucco to finish it.
    My question is, can I just use a skim coat of Portland cement to fill in the old cracks (see picture below) and smooth out/put over my new perlite/Portland insulating layer in the front re build section???? OR What should I use?
    See pictures for reference. Just looking for the best way to finish given I'm not a professional stucco person.
    Dick
    aka thebadger
ID:	422378 Click image for larger version
