K-rend on top of vermicrete layer
  • Lucag
    • Jun 2018
    • 65
    Hello everyone!
    I am finishing up my dome with :
    - 7.5inches ceramic blanket
    - chicken wire and 6:1 vermicrete mix (1.5 inches)
    - k-rend base coat
    - k-rend silicon topcoat
    My question is:
    What should I Use to cover up the front and side of my dome and hide the cal. Sil board?
    - vermicrete
    - poor man's mortar mix
    - or K-rend?
    See photo of My oven front here:
  • shanxk8
    • Nov 2010
    • 201
    It looks like the 7+ inches of CF blanket will bring your layers at least out to the edge of floor bricks & CF Board (if not farther).
    I would suggest you just carry the vcrete layer down to your hearth and do the same with the krend layer. If the CF blanket layers get wider than the floor brick & cf board, it would probably help to have some of the CF blanket insulating those floor brick as well, so heat doesn't escape your floor as quickly.
    Your oven is looking super so far
    David in Calgary
    My Build Thread
    • Lucag
      • Jun 2018
      • 65
      Thanks for your answer! I meant 7.5 cm ceramic blanket, not inches I did use vermicrete and left a few cm on top for k-rend, which I will apply in 7 days.
      ​​​​​​All looking good so far!
      Photo here:
      • shanxk8
        • Nov 2010
        • 201
        The venerable david s drew out what I was trying to describe in this post.
        I am very excited to have started my project which consists of a masonry fireplace, built in grill top, refrigerator, and a pompeii dome. this has been long in the making. I have read many good posts on this forum and I can only hope to achieve the results as all of you have had with your builds.
        David in Calgary
        My Build Thread
