I know this must have been covered before, what should the foundation dimensions be to build a corner pompeii oven?
42 inch corner oven slab dimensions
All you need is to cut a sheet of cardboard out that is your chosen size. Add all external things like brick, insulation, and enclosure if doing one and you will have your required size. I believe fo my 40" oven i was at 70" x 70". I believe a 42 would have also fit that base. I was on the corner as well.
Randy
