Some questions I have:
1. Does the vent landing and outer arch have to be firebrick? If not, should I still use the flue set mortar? -- I think a lot of people have a one and a half brick length for their landing (from inner arch outward). I'm pretty sure the full length brick arch I'll make directly in contact with the inner arch will be firebrick. Then I was planning on using a half non-fire brick for the outer arch. Will this be okay?
2. For the chimney, I'd like to do the clay flue then surround it with bricks, anything I need to consider for this? Once again, do I need to use flue set mortar for this? Do I even need the clay flue if I am using bricks? Thanks!
