First lot of questions:
I've roughly laid out the thermolite blocks. The template is for a 36" oven. There is 4"-5" from the template to the side blocks but only about 1"-2" to the back.
I was planning on having two layers of 1" ceramic fire blanket and filling all the rest with loose permulite.
So the whole enclosure will have loads of thermal insulation apart from the rear first row of the pizza oven, which will only be fire blanket and 4" thermal block.
Does this sound ok?
Is a 5" flexible chimney liner ok to use as I want to feed it in to the grill chimney?
Does this sound ok?
