Finally, I am taking the plunge and asking for help in the forum, rather than just absorbing the amazing information here for everyone.
I am hoping that, having got about half way through my build, I can lean on the experience and support of this community to help me avoid any sizeable mistakes, and aware that this is when it gets a bit tricky!
I've got to a stage where it is now, hopefully, all about the build of the dome (and the insulation underneath/around it); each day I seem to come up with more questions, than answers to the previous days' questions so here's where I can share and benefit from your cumulative knowledge.
I need to resize some more photos in order to upload them under this topic (or more likely set up an album) and bring them to life but I will start with a dump of the current situation and questions and a few images of where I am right now.
I've built the concrete base structure on which to build the dome, the intention is that the dome will be 36-37 inches internal diameter...(I am just measuring that out and not worried if it is one or the other, just want top make optimum use of the space available.) I've bought most of the material that I thought I needed from a Kiln company, to save money primarily, and so some of the materials I have bought will not be perfect, but I am hoping that without too much further investment, I will be able to complete the build without compromise and with an oven that functions pretty close to perfect and I can be proud of.
Things I know I need to do fairly soon (please excuse any poor descriptions or using the wrong names for things!):
1. Drill 2 or 3 holes beneath the concrete oven to allow for any water under the insulation to escape and fix mesh on the underside of the hole in the concrete slab
2. Lay mosaic tiles - based on what I have read across the forum - across the footprint of the oven
3. Measure, cut and lay the oven floor fire bricks using a circular template to determine most efficient use of bricks then cut the same dimensions in insulation board to lay under the fire bricks
4. Not lay the first layer of dome bricks in the orientation you see in the photos, but to lay them as soldiers
5. Jigsaw the inner plywood for the oven and fix the IT to the centre of it. (IT is nearly built)
6. Build the forms to support the two arches (below question on dimensions of the two arches will determine that)
Questions I need to answer relatively soon (there will be plenty more):
1. For a 37 inch (94cm) oven, with a likely internal height of 19 inches (48cm) when it is built - what height and width should the oven door and outer door be?
Inner - My initial research suggests inner oven door (*the one effectively built into the dome structure) should be c.62% of dome height so 11 and 3/4 inches (30cm) and the width is less critical but should be about 18 inches wide.
Outer - which I will build out of fire bricks could simply be 2 inches wider (20 inches) and 1 inch taller - this in effect creates the seal for any door I construct to be inserted and pushed up against the inner oven door/arch and rest against a sufficient 1 inch 'lip' of firebrick. The distance between the inner and outer arches is likely to be c.400mm - between one and a half, and two bricks (length-wise) depending on the final room I have to the front of the concrete plinth.
2. After the mosaic tiles, I have Calcium Silicate board (melting point 1345 degrees celcius) 230-290 kg/metre cubed bulk density. Then I was intending on laying the firebricks on top of the Calcium Silicate (with some building sand to enable the best level and fit for the fire brick floor). The board is 50mm deep. My question here is do I need any additional layers between the main Concrete slab (*and mosaic tiles for drainage if water gets underneath the Cal-Sil board) some builds I have seen use the vermiculate concrete mix at this point and add another 50mm on top of the cal-sil board, before then adding the sand and fire brick floor...?
3. I have a choice of using a deeper firebrick for the floor of the oven, should I do so, or use the same slightly shallower fire brick (I probably have enough of both so it is an open choice at the moment)? The depth options are "Firebrick 42GD -230 x 114 x 64mm" (the deeper ones) or "Firebrick 42GD -230 x 114 x 52mm" my preference would be the thicker ones for heat retention but likely a slower heat up time. Is this a correct assumption?
4. For the concrete/mortar to fix the dome half-bricks in place, I have bought two products and I'll be honest, I didn't do my research on suitability so know that they won't be perfect here's what I've got... Firstly, Castable - C1400, Secondly I have 60GD HS Cement. Can I use one or both of these castable and/or cement options to secure the bricks in the dome effectively?
(I am aware there is the conventional and heavily recommended 3-1-1-1 mortar mix which I could have opted for (and may yet have to!) although in the south of London I've not found a local place to buy fire-clay yet so hoping I can use what I have. )
Requests for clarity, and then any help, guidance or corrections-before-the-event all greatly appreciated and taken in the spirit intended! I'll set up a photo album to better tell the story of how I have arrived to this point very shortly.
Tim.
Tim.
