Hello Les, Wow great job on your dome/entire build, I have read thru your build couple times looking at all your pictures and good info, I see why your a well known pioneer of this forum. Your dome brick joints look as close to perfection as humanly possible, what type saw jig did you use? Also did you use or were any angle /bevel calculation spreadsheets available to you when you were building your wfo. Im still struggling with my brick cuts and very curious on how you made your cuts almost look mortarless. Im not looking to be as pretty as you, no pun intended. But would like to improve on my brick cuts as seen from inside of dome.
again great build
thanks
Ivan
again great build
thanks
Ivan
