Hi
I am reading page 13 of the Pompeii oven instructions - the dimensions.
I would really like to build the 42" oven, but, as you might have seen on my other thread, the base slab I poured was really designed for a barrel vaulted oven - which I have now decided against.
Here's a pic of the base. It measures 50" wide by 56" deep, by 6" in height.
[IMG][/IMG]
According to the info on page 13, the 42" oven needs a base of 69". Am I reading that correctly?
So I start out with an exterior dimension of 51", which exceeds my base, then by adding the insulation and other layers, end up at 69"?
If this is not going to work in my case, can I still maximise my oven internal diameter without compromising the thermal mass and the insultation? I do want a proper dome, not a gherkin shape.
Many thanks.
[IMG][/IMG]
Many thanks.
